nachschub
MSI:
GIGABYTE:
  • AX370-Gaming K5 Beta F3B
    AGESA 1006
    New memory multipliers: 3200, 3333, 3466, 3600, 3733, 3866, 4000MHz.
    26 memory registers open
    IOMMU Grouping
    EZ Overclock Tuner
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming K3 Beta F3A
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming Beta F3A
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AB350M-Gaming 3 Beta F5B
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AB350-Gaming Beta F5B
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
ASRock:
  • X370 Taichi Beta L2.36
    AGESA Microcode 1.0.0.6
  • X370 Professional Gaming Beta L2.36
  • X370 Killer SLI 2.40
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a"
  • X370 Killer SLI /ac 2.40
Reaktionen: Andreas und Saibot
neue Biosse brauch das Land
MSI:
  • X370 XPower Gaming Titanium and beta V1.74
    Improved memory compatibility.
    Fixed PCIe Hot-plug function issue.
  • B350 Tomahawk beta V1.64
  • B350 Tomhawk Arctic 7A34vH4 and beta VH52
  • B350 Gaming Plus 7A34vM1 and beta VM22
  • B350 PC Mate 7A34vA4 and beta VA.52
  • B350M Mortar 7A37v14 and beta V1.54
  • X370 Gaming Pro Carbon 7A32v15 and beta V1.63
  • X370 Krait Gaming 7A33v13 and beta V1.43
  • X370 SLI Plus 7A33v33 and beta V3.44
  • X370 Gaming Pro 7A33v42 and beta V4.33
  • X370 Gaming Plus 7A33v52 and beta V5.33
  • A320M Pro-VD/S 7A36v21 and beta V2.23
  • B350M Mortar Arctic 7A37vA4 and beta VA.52
  • B350M Bazooka 7A38v14 and beta V1.54
  • A320M Bazooka beta V2.33
  • B350M Pro VDH beta VA43
  • B350M Gaming Pro 7A39v26 and beta V2.71
  • B350 Gaming Pro Carbon beta V1.43
  • B350 Krait Gaming 7B08v11 and beta V1.22
GIGABYTE:
  • AX370-Gaming K7 Beta F4E
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming K5 Beta F3C
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming K3 Beta F3B
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming Beta F3B
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AX370-Gaming 5 Beta F6G
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AB350-Gaming 3 Beta F7B
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AB350M-Gaming 3 Beta F5C
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
  • AB350-Gaming Beta F5C
    AGESA 1006
    IOMMU Grouping
    EZ Overclock Tuner
ASRock:
  • Fatal1ty X370 Professional Gaming 2.40
    Update AGESA to 1.0.0.6.
  • X370 Taichi 2.40
  • Fatal1ty X370 Gaming K4 2.50
  • X370 Killer SLI /ac 2.50
  • Fatal1ty AB350 Gaming K4 2.50
  • AB350 Pro4 2.60
  • AB350M Pro4 2.50
  • AB350M 2.50
ASUS:ROG Crosshair VI Hero beta 1401
Prime X370-Pro beta 0803
Beta BIOS with AGESA 1.0.0.6
Prime B350-Plus beta 0803
Reaktionen: Andreas und Haddawas
Danke Dir, aber wieder nur eine Beta ohne Agesa 1.0.0.6 fürs MSI Gaming pro Carbon.
Aber werde die Beta trotzdem mal ausprobieren.
Auf jeden Fall sind Sie / wir auf dem richtigen Weg.
Profil 2 aktiviert und 3200MHz laufen, ich habe noch nichts weiter eingestellt.
War ja bisher garnicht dran zu denken.
Mit der Beta 1.63 sind nun auch Einstellungen an den Subtimings möglich .
Werde nachher mal Screenshots davon machen.
Edit: Hier mal ein paar Sreenshots
Aida Sreenshot, beim Ram alles auf AUTO nur die Spannung auf 1.35v gesetzt.
Reaktionen: Saibot
Ernüchterung....:cry:
Der PC läuft zwar mit den 3200Mhz, aber alles andere als stabil, so viele Bluescreens hatte ich schon ewige Zeiten nicht mehr.
Bin wieder auf 2667Mhz zurück, dort läuft das Ryzensys stabil.( Aber immer noch mit der 1.63 Beta )
Ich werde auf die Offizielle AGESA Version warten, ehe ich mich an die Subtimings begebe.
Schade :(
Schade :(
Hatte ich zu beginn von x99 auch, 500€ Ram gekauft und nix ging... dann von 3200 zurück auf 2400er ram... gleiche testwerte durch viel bessere Timings.
Ich drück dir die daumen das es läuft
Mit 2993Mhz und leicht entschärften Timings läuft es eigentlich ganz gut.
Auch die CPU macht schon Spaß, ich muss mich nur noch intensiver mit beschäftigen.
Hab gerade Cinebench mit 4,0Ghz und Ram mit 2993Mhz laufen lassen.
Bin von den Temperaturen positiv überrascht, habe hier im Zimmer 23°
Die Corsair H100i kühlt mMn nicht schlecht, Lüfter laufen auf 50%.
Finde ich gut :) Oft ist es ja nur ein "Bauteil", aber mit ein wenig Begeisterung kann der Umbau und die Auseinandersetzung mit Bauteilen schon enorm Spaß machen.
Die H100i (Erste Version)
habe ich erst vor 3 Tagen verkauft. War schon ziemlich brüchig an den Anschlüssen, war aber vor 4-5 Jahren der Verkaufsschlager und auch wirklich gut. Vergleichsweise besser wird wohl die V2 sein die du besitzt oder?
Alternativ kommt für mich nur noch die 115er Serie von Corsair ins Haus oder BQ 280 bzw die neue 360er (Weil der Service top ist) und die Fractal Design so wie TT :)
Kann ich nicht wirklich was zu sagen, denn dies ist meine erste AIO.
Hatte bis dato nur normale :) ..äh Custom Waküs.
Aber die 100er Version die ich hier habe macht ihren Job ganz ordentlich, irgendwann muss sie aber
bei z.B. Prime oder ähnliches Ihre Qualität auf Dauer zeigen.
Cinebench ist ja doch nur ein sehr schneller Test.
Wie laut ist die AIO bei dir Andreas?
Bin mal gespannt wann das Bios aus der Beta Phase kommt, dann wird es direkt installiert.
Könntest du das nächste mal eventuell die Bilder in unserer Galerie hochladen, das bisschen blöd mit soviel Werbung ;). Kannst dir auch ein Extra Ordner dort machen, ist hier etwas anders wie in den anderen Foren wo das nicht möglich ist :).
Ich hatte das schon in der Galerie geladen, dort war es aber so klein das man keine Details erkennen konnte.
Ich finde die AIO relativ leise, würde es wieder so machen.
Gesendet von meinem FRD-L09 mit Tapatalk
